BootP - Keep losing IP Address when I power down PowerFlex 525
Aug 2016
Virginia
343
Good Morning ,
I used BootP to establish the IP Address for a new PowerFlex 525 . Every time I power down the drive , I lose the IP Address. I am confused about BootP. Should I enable or disable BootP ? Could you folks explain BootP , and how it works.
Thanks so much.
After you set the IP address you need to disable BootP. Doing this from the Him may be easier then using the software.
HTH
You must set parameter C128 to 1 along with setting the IP address. This tells the drive to use the IP address in the parameters rather than get one from bootp.
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
350
I am not sure what i am doing wrong laptop ip 192.168.1.233 with subnet mask 255.255.255.0 micro820 ip unknown 1) i connected a micro820 and my...
3,924
Hello. I'm using bootp to set an ip address for a 1747L551 processor. The bootp program immediately sees the mac id and I am able to enter an...
1,190
I have spent hours trying to search and resolve this, but no luck. With my fairly new laptop running Windows 10 Pro, I cannot use the BootP...
37
27,271
Started at a new job. Trying to bootp a L17er. Bootp will not work at all. Tried other plcs and it will not populate the MAC relation for...
2,786
