BUS FAULT - How to have it?
Jan 2007
Bangalore
I have a S7 300 (CPU 315-2DP) plc. For doing testing, I would like simulate a manual bus fault but it is not coming up. The Bus Fault Indicator on the CPU does not blink.
I tried shorting A1 and B1 of the MPI Profibus Cable that I am using to communite to PLC, but it is not hapenning.
Can someone help me in simulating the BUS Fault. This would be of great help.
Best Regards,
Jagdish Kumar
I have never attempted to do this so can't really help, but others who my log on later may, a couple in guys in particular.
Please don't fill the board by repeating the same question, have patience and someone will come long eventually.
What is in the hardware config ? - it needs to be configured with something on the profibus before the bus fault will be generated.
JohnW said:
Configure a device that is not preset or disconnect a configured device and a bus fault is generated.
Configuring a Device which is not present -> I got a System Fault NOT Bus fault.
Hardware that I have is : S7 300 PLC (315-2DP) and a digital relay output module and a profibus MPI cable.
Baudrate used to download to the PLC is 187k.
Hi All, We are receiving the PointBus Status Fault (led is flashing red), whereas all the other status leds are solid green. Just to eliminate...
916
All the servo guys out there looking for a little help? I am having issues with a Kinetix 5500 keeps giving me S39 BUS POWER LEAKAGE FAULT. Does...
1,956
Hello guys, I am facing field bus communication fault 45.Abb drive model is ACS850. What could be reason for this fault 45 ( Fieldbus...
1,983
Hi! I communicate with an onboard communications board modbus RTU. I communicate with 5 VFDs (Parker AC10) and each has 4 calls of MB_Master. So...
19
8,158
Hi everyone, I am working with 3 Franklin Electric P Series drives. I am communicating with the drives via Modbus 485 with a MVI69E-MBS Prosoft...
1,557
