C-more Micro: Function key to toggle a bit
kolyur
Oct 2004
Wooster, Ohio
1,602
As the title says I want to toggle a bit with a function key (EA1-T6CL). I know that I can create a Pushbutton object and assign a key to it, but then I'm left with a touch button that does the same action. I don't want the touch button--just the function key. I tried turning off the visibility of the pushbutton, but found with the Simulator that this disables the function key as well.
It doesn't make sense that the only purpose of the function keys would be to duplicate existing touch buttons. What am I missing?
Drag the button into the Gray area off of the visible potion of the screen. It will still act like it is on the screen, but the operator cannot get to it.
I have both an Automation Direct Click Plus PLC and a EA3 series Micro HMI that I’m getting a feeling for before a big project since I haven’t use...
1,241
Does anyone have example code of how to read/write a discrete push button from a C-More Micro to a DL05. I just bought these two items and I am...
1,014
has anyone used a cmore micro hmi with a compact logix plc. I see that there is a cable that connects the two but compact logix uses description...
2,408
Does anybody know if the cable between a click PLC and a Cmore micro HMI is a standard phone cable? Thank you, Dave
2,388
I have a modicon m340 processor and a c-more micro hmi and can not figure how to address them correctly to get them to talk to one another. i am...
2,128
