cmore micro hmi
Jacob H
Nov 2012
Baltimore
has anyone used a cmore micro hmi with a compact logix plc. I see that there is a cable that connects the two but compact logix uses description based tags and cmore micro uses address based tags.why would there be a cable available if they are not compatiable.
Well, a lot of the communication options on the A-B products are shared across multiple platforms. It could be that the cable you found works with a smaller platform like the MicroLogix and just happens to be similar to the comms options for the CompactLogix.
Sorry I couldn't be helpful with your actual issue, but that at least offers a plausible answer to your question about why.
You would need to use the feature "Map PLC/SLC Messages" in the PLC which creates a SLC-like file number and addresses for the panel to communicate with. See helpfile topic CMM310 for details.
Does anybody know if the cable between a click PLC and a Cmore micro HMI is a standard phone cable? Thank you, Dave
2,375
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
112
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
502
I working on installing a EA9-RHMI so I can use a TV screen for my HMI. I wanted to be able to show multiple screens on the TV at one time, but...
1,322
I am stumped here. Anytime I put the PLC into run mode the HMI comes back with PLC-497: error code 0x010100 returned from PLC on CIP and also...
2,003
