Can someone tell me why I cannot communicate with another PC port. DirectSoft only sh
piscis
May 2003
241
Can someone tell me why I cannot communicate with another PC port. DirectSoft only show Port 1 and 2.
I’m using a Laptop with an RS232-USB converter and need to connect to a 260 on PLC port #1 with my PC on port 4.
Silly question. How do I do this? I’m getting the “Port is not present…..” message on PC port 4 / 5 / and 6.
Why I’m not able to choose on DirectSoft comm. Link the PC port I want to connect to?
Open up the DSLaunch window. Under Utilities, you will see a DS500.ini file. Double click on it. Scroll down until you see the section entitled, "[devasync.dll]". Change the 0s to 1s for the ports you want enabled.
If you are using a DirectSoft version previous to DirectSoft 5, then you will need to go to your C:\Windows folder to find the .ini file. If you have version 4, it will be a DS400.ini file, etc...
I got some help from my journeyman today and i want to know if anyone can see if what i have is going to work or not. This will be ran with...
2,836
This is the simple program I wrote to save the maximum values of some analog signals. Initially everything seemed to work OK - the carrier tray...
20
4,722
Hi, I'm just wanna starting of PLC cuz needed by my work. I had H2 Plant Sysmac C-200 Hg with CPU 43-E. Could someones tell me what this PLC's...
1,733
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
390
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
906
