Can't Assign Input/Output address to Profinet S7-1200
juanmdx
May 2007
SLP
281
Hello,
I'm working on project where I'm using an S7-1200 PLC, and I'm working with 3 devices that I'm connecting on a Profinet network.
I connect (on the TIA portal) each device and assign the IP address, and the TIA portal assigns the slot and the input/output addresses automatically, but when I connect the third device and asign the IP address the sofware doesn't assings the input/output addresses.
The devices are differents, and this happens with anyone of them (as long as it is the third one).
Because the system doesn't assigns the input/output addresses I can't compile the project nor download the hardware configuration.
Does anyone knows how can I correct this?
Best regards
Juan
Which version of TIA are you using? If its V10.5 or V11 just upgrade because not even Siemens knows how to get those to work properly.
Next, do you have enough connections available on the PLC, if the third one is failing it may be due to running out of connections.
Then look at how you are connecting them in devices and networks topology view, portal sometimes does funny things if they are not all connected. You can just use unmanaged switches to fool TIA if you need to.
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,028
On my HMI-1200, I'm trying to assign the image of a floppy disk ("save" icon) to a function key. I couldn't find one in the default drop-down...
599
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,135
Good Morning, I'm not sure if this is a stupid question, but I've been working with FTView ME for quite some time now and I can't solve this...
1,495
Hi I have a few Movimot motors on profinet, where i need to change the profinet name on the motor. I have been true this before, where i deleted...
2,431
