Siemens S7/TIA v16: WinCC: Trying to assign a SAVE icon to an F-key...
Mas01
Oct 2020
Leicester, England
1,109
On my HMI-1200, I'm trying to assign the image of a floppy disk ("save" icon) to a function key.
I couldn't find one in the default drop-down list (there was things like, right arrow, down arrow, etc) but no SAVE icon.
So I created one and imported it as .PNG.
It appears on the WinCC screen page (albeit slightly squashed - see pic).
But when I download to the HMI, the image does not show up - as though the imported image is not recognised.
Is there a Save Icon built into TIA portal somewhere that I can use? Thanks
don't know the later HMI's but I would just use text on the button, simple informative & often use a text field above a button if more information is required i.e. "Save Parameters".
I have had problems like this, sometimes you have to update things like libraries ^& download them to the HMI.
Other reasons can be the bitmap or what ever is not a format recognised by the HMI, you need to import it into the library so it is downloaded to the HMI, what i did on one system is take an existing icon into paint, then using the bitmap just drew it so it was the same size, type & had invisible border etc. could be a number of reasons it is not displaying.
Cheers - for now, I'll take your pragmatic approach and use Text instead of an image.
I'm finding that PLC programming is a double-edged sword...there's the code (which, in reality, very few people will see) & then there's the HMI which is open to criticism from everyone! :).
Weird, but if there is no event function associated with the F key, the image is not displayed. I added a function (to activate a screen) and the image was then visible.
You're absolutely right.
I just added an event linked to the F-key, downloaded to the HMI and now the SAVE icon is being displayed...it's still a bit squashed, but at least it's working.
Cheers
In OB1, I'm monitoring some values (first pic). The values are what I expect. At the same time, I'm monitoring the same values in the DB where...
651
Siemens S7/TIA v16: "Overwrite if object exists online?" HMI loading message... Thus far, I've just been ticking this box, just to get the HMI...
769
I'm having a bad day. Daft question coming up...Anyone know why I can't add anything into this DB? Add button is greyed-out. Thanks
1,597
I imported a customised shape into the project, but I don't know how to actually add into on to a specific HMI screen. Do I use the Graphics menu...
661
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
947
