Siemens S7/TIA v16: Monitored values don't match...why?
Mas01
Oct 2020
Leicester, England
1,109
In OB1, I'm monitoring some values (first pic). The values are what I expect.
At the same time, I'm monitoring the same values in the DB where they are written to, but instead of seeing the values, I see "????" (second pic)
Does anyone know why these do not match?
UPDATE:
In case it helps someone in the future, I clicked inside one of the pink cells and a message tells me that "the maximum number of monitoring operations permitted has been reached".
I tested this by adding another tag to the list to monitor it and it also appeared with "????" next to it.
I originally thought that the "???" meant the PLC did not know the value of the tag...this is not the case - the PLC has just reached a limit and will not display the monitored value.
Siemens S7/TIA v16: "Overwrite if object exists online?" HMI loading message... Thus far, I've just been ticking this box, just to get the HMI...
769
I'm having a bad day. Daft question coming up...Anyone know why I can't add anything into this DB? Add button is greyed-out. Thanks
1,597
I imported a customised shape into the project, but I don't know how to actually add into on to a specific HMI screen. Do I use the Graphics menu...
661
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
948
I want to draw a shape on a screen page in TIA/WinCC. It's roughly the shape of a canal boat hull -see picture. I couldn't find any "free-form"...
1,552
