Can't connect WinCC 6 to the PLC
Sake_no_oni
Jan 2013
Dnipropetrovsk
18
Dear Sirs,
I’m having some troubles with connecting WinCC 6 to my Siemens PLC (6ES7 307-1EA00-0AA0) via TCP/IP. The Ethernet module (6HK7 343-1CX00-0XE0) seems to be configured correctly, as well as its physical connection to the PLC. When I activate the runtime I have all tags’ status “no PLC connection”, BUT there is some package exchange between the PLC and a computer. The package exchange starts the same moment the runtime is being activated. TCP/IP driver’s properties and system parameters are ok, computer and PLC are both in the same subnet and the module’s rack and slot numbers are specified correctly, the SQL server is also on. I can’t figure out what exactly I’m doing wrong. Any help appreciated!
Best regards!
Connection is on, thanks! Unfortunately, another problem appeared. The analog tags do not show current values, instead they show zeros, and their connection to the PLC is not stable: it turns on and off all the time. But, in the same time, the discrete tags are absolutely ok, and their connection is stable. I’ve forgotten to mention that there is a Simatic HMI panel connected to the PLC via MPI. Could it cause the trouble?
Regards!
Hi everybody. Please help me. i want to know is it poosible to write SCADA program for a CJ2M-CPU31 OMRON PLC in WINCC program? Programming of...
1,431
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,249
Hi I need your help I want know that how many stations(wincc,op panel ,..) can connect to a plc S7-400 cpu417. According Technical...
2,300
If you shall ever have to make a WinCC Flexible panel in order to connect it to an S5 PLC via the PG port (for example for replacing an old defect...
2,215
Hello everyone is it possible to connect the studio logix5000 emulate to a siemens wincc 7.5 running on another pc? if so, what do i have to do...
504
