Can't download to panelview 800 from CCW
husky
Jun 2015
Melbourne
20
Hi guys,
I have a micro 830 controller and panelview 800 but for some reason I can't connect to the panelview to download a program. The panelview shows up as an unrecognised device.
I notice the panelview firmware is version 4.013 and on CCW under general graphic terminal information it is shown as version 2.010 . Is this the same as firmware? If so how do I get it to update to the current version? I'm wondering if this is the problem.
I'm using CCW release 8.000
Any help greatly appreciated.
no a solution for your Firmware Problem,
but have you tried to copy the runtime with a usb pendrive or sd-card? Just to see if the runtime runs on that Panel (with the Firmware).
Did you set that IP address, or is it something it set itself? I mainly ask because usually when I see items in my browse it's because I added the IP address to my tree manually and unless you're on the same subnet it normally doesn't work right. If you're in the same subnet, I'd try using a webpage to go to the IP address of the terminal. I know most of the other HMIs that CCW works with have webpages you can upload/download projects with. I'm unsure of the 800 though.
Edit: I see the IP address came from DHCP, so I am almost certain you didn't set it yourself. Change to static, set it in the same subnet, then try again.
Hi, guys... I know this should be pretty simple, but for the life of me, I cannot make it work. I've just developed a new application in CCW...
5,533
I have been trying to add a button to an HMI Panelview version 5.1 for a couple days. Each time I download I get no data in my buttons, only...
210
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
903
Got a problem on an install this weekend I'm hoping someone can help out on. I'm upgrading an old system with a SLC5/04 and Panelview 600...
1,137
Hello. At work we've acquired an old tubing end former machine we're trying to get running. The machine came with 2 floppy disks that have .RSS...
26
5,689
