cant write to Altivar 58
Nametag
Mar 2013
Calgary
Hello
We have just installed a hot standby rack into a plant we removed a 140 CPU43412A and installed 140cpu67261 processors. no program changes no IO scanning changes with regards to the drives. After bringing everything online the process works smoothly but we noticed that four VFDs were not working properly. There are Altivar 61 and 71 drives(work perfectly) and four altivar 58 drives in the MCC all connected to the same switch. The 58s in IO scanning in unity have Three lines of scanning each, the First is read/write and the second and third are only read. The second read and third read were coming back from the drive ok but the first line (read/write) was not reading or writing at all. we decided to split the first line into two seperate, a read only and a write only. The Read from the drive started to work properly but the write still will not work. The Registers have not changed from the old program.
I have tried to use a MBP_MSTR block to write to the drives but no response.
Hi I want to press a button on the HMI screen and write to a bit within an Integer within a control logix PLC. The iFix version is 5.5 and using...
2,406
I have set-up an integer data file "N50" with 100 elements. There is nothing being written to these locations from my logic. While on-line, I am...
2,100
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
721
Good morning, we have a lot of coolant mist around our machines and sometimes the fans on the drives inside our electrical cabinets will suck the...
1,311
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,394
