CCW and Micro 820
dginbuffalo
Dec 2010
Buffalo,NY
630
Hello all- Is there a way to use a timer enabled bit in CCW? When i try to use a contact and reference say TIMER.IN, it causes an error when I build the program. I was looking to find out when the timer is enabled but it looks like the only work around might be if I say the ET is greater than zero.
I don't think there is. The only sub-elements you can use from TON_1 are the output (.Q) and the rising edge of the input (.REDGE).
Evaluating the elapsed time <> 0 would be an easy workaround to read.
Another workaround would be to replace the TON with an program-scope BOOL tag, then put that tag in an XIC with the TON on a separate rung.
Coming from the A-B operating systems and syntax, using PLCOpen or ISAGraf is always an exercise in modifying your thinking to fit the toolset.
10-4. Thanks Ken. Wish I hadn't wrote all the code first-lol!!!
If you are looking for a Timer Timing bit like the one used in RsLogix I have a way to do that.
I am traveling so I can't do a screen print. So I will try and talk you through it.
1. Put a branch around the timer.
2. On that branch put a XIO your_timer_name.Q and a OTE your_timer_name_TT.
So if the rung conditions befor the timer are true and the timer is not done your_timer_name_TT is true.
Actually looking for timer enabled timer.en
Good solution for a timer.tt though. I need a few of those instances too!
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
293
I am trying to upload from a remote Micro 820. I am getting this error message. unable to load project with limited license. The target '' used...
1,682
Hello- struggling with multiple issues on the Micro 820. #1) Can't flash without getting error. Have a flashing fault light but do not know how...
4,587
Hi, I can't connect to a Rockwell Micro850 using Connected Components Workbench (CCW) 12.00. - I can ping the PLC - I can flash the PLC (from 10...
1,529
