Changing a pv+ display based on a tag value
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
I have a Panel View + 600 using FT View ME 7.0
I have a display that accepts data entry. If all the data is entered properly then a PLC tag is set. I would like the the PV to change to a different screen automatically based on that tag being a 1.
any ideas on how to do that?
Thanks!!
First you need to assign unique screen numbers to each display in your application.
Look in Global Connections, Display tab. "Write Display Number" will change the screen to the value that you enter in that tag. You must write a zero back to that tag in order to give the operator the ability to change the screen from the HMI. Leaving a value in it will force the HMI to always be on that screen.
Good Morning , On my Panelview Plus ( CompactLogix ) I have a knife position that is showing 0.000 to 0.630 on my HMI and also my program ...
2,205
Hello Guys, I am new with VBA and am not very familiar with how to change the string display through VBA. Right now, I am trying to make the...
3,575
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
259
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
500
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
101
