Changing and OLD PLC, see attached file.
widelto
Jul 2005
Barranquilla, Colombia
3,392
Hi Guys:
PLC Klockner Moeller now Eaton.
I need to updload (rockwell terminology) the program inside this plc.
My customer wants to replace it and I want to know what there is inside.
Please can you tell what is the name of the software used for this kind of plcs.
best regards,
william
According to Eaton it's this
The XC100 devices are programmed using CODESYS 2, while for the XC-202 devices CODESYS 3 can be used alternatively. The software is not only easy to handle, but also offers a variety of useful functions that make debugging, testing and commissioning both quick and easy. The integrated online simulator makes it possible to quickly identify and remedy any programming errors.
https://www.eaton.com/gb/en-gb/cata...omation---sensors/xc100-200-modular-plcs.html
There is a download link on this site.
Parky:
That download link goes in circle to nowhere, can i try to download generic codesys 3 from another download center ?? or it has to be this one.
My cpu is XC201
Thats interesting when
Klockner Moeller was the AB of Europe
I was still working printig presses
I found that in most cases you could use a AB part as a direct replacment
I ofter wonderd wondered if they were not mad in the same factoy
AB's where maid in switzerland
as for the software it would only make sence thet thy would use different softeware
I have no idea I just looked at the website, I have never used codesys although it seems both versions they show will program that PLC, I bet if it is a download then it may only be a trial.
You cannot upload the program (PLC->PC) unless the programmer downloaded the source code to the PLC. If they didn’t then you are out of luck.
I am considering buying and old machine. It currently has a very old telmechanique plc. I would like to upgrade that to an Automation direct...
2,806
I just got a work order to change a rusted out box with a bunch of wires going through it. The box has conduits coming from it that goes in 5...
3,467
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
235
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
467
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
89
