Changing baud rate of a DHRIO module
ettikudiappan
Apr 2002
Singapore
131
Hi
I am trying to increase the baud rate of a 1756 DHRIO series B module from 57.6kbps to 230 kbps. You can not do it through switch settings or using RsLinx (even Gateway version). From the local AB tech support, I learnt that we can change the baud by setting the channel selection switch to 2 for both the channel A and B. But this does not work (when configuring a DHRIO in RsLogix 5K, press help and this procedure is listed). Has anyone done what I am trying to do?
I know that series C comes with default 230 kbps.
To change series B to series C, flash the series C firmware to the series B DHRIO module. Setting the BAUD rate switch on Channel A to 3
will allow 230Kbps.
I get the error "Error changing baud rate." for a QPICTAE0000 using the Tool Port.
1,304
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
260
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
500
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
101
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
303
