changing panelview 2711 from ethernet to serial comms
diat150
Mar 2006
Louisiana
1,474
I need to change a panelview 2711 comms from ethernet to serial. it talks with a l34 flex processor. Im about to try and figure it out on my own but was hoping someone could enlighten me in case I cant. thanks.
PanelView Standard terminals can only use their network port for communications to controllers. If you have a PanelView Standard that has an Ethernet port as well as a serial port, the serial port can only be used for upload/download or as a printer port.
PanelView Plus terminals can use any installed port to communicate to controllers. The connection path is defined in RSLinx Enterprise, on the "Target" tab.
Post the exact part number of the PanelView you are using.
In general, an Ethernet connection is much faster than an RS-232 serial connection. Why do you intend to switch ?
I was able to get it figured out. this will probably sound ridiculous to most everyone but the reason we have to change it is because of a standard.
Hello all, I am changing the target device IP directly on a Panelview1000, and every time power gets cycled it seems to "forget" the new target...
2,564
A customer just asked me if I can replace the backlight on this Panelview Plus 600 without affecting the memory. Well.... I've programmed a...
3,485
Good Afternoon , I am modifying an existing system . This system presently has the following...... MicroLogix 1500 Serial Communication...
6,674
Hello, I recently changed the IP address of a Compactlogix L32E and an asssociated Panelview 1000. I can ping both of them so I know that the IP...
5,533
Our customer has requested that we have any faults show where the fault is on the machine displayed on the PV screen. Is it possible to import a...
2,207
