Changing images Panelview Plus Compact
edpg1
Nov 2012
Ontario
19
Our customer has requested that we have any faults show where the fault is on the machine displayed on the PV screen.
Is it possible to import a slew of pictures (10-15 at most) and have the fault bits from the PLC switch the displayed image in the image box or active x control?
I know I could have 10-15 images ontop of each other and make them visible when required. I am hoping to avoid this.
This is an ordinary feature of the Multi-State Indicator object. Each State of the indicator object can have its own text and its own image.
I think Version 7 of FactoryTalk View ME even supports PNG image format, which is much less memory intensive than JPG or BMP.
Thanks Ken,
I was unaware I could do images on a multistate indicator. I was under the impression it was just colors and text.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
239
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
476
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
94
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
292
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
216
