Changing the backlight on a Panelview Plus 600
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
A customer just asked me if I can replace the backlight on this Panelview Plus 600 without affecting the memory.
Well.... I've programmed a Panelview about 10 years ago, but I've never tried to repair one. it seems pretty straight-forward, but I don't know what I don't know. I tried referencing the manual (see below) but they don't show the operation for a 600, just 700 and up. The customer is an hour away, so I don't have an easy opportunity to poke around. Anyone have some knowledge to share?
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2711p-um001_-en-p.pdf
Best thing I can tell you is call a local AB distributor or wait till someone else chimes in here, I have used these before but it was another life ago and I just don't remember, Sorry I can't be of more help
Well....
I got this back from my distributor:
The unit you have is a PanelView Plus 600 terminal. This unit doesn’t have a replaceable backlight see below:
The following products are not supplied with Backlight replacements (send the unit in for repair):
· PanelView Plus 400-600 terminal
· PanelView Plus Compact 400-600 terminal
· PanelView Plus 6 400-600 terminal
· PanelView Plus 6 Compact 400-600 terminal
· 1500 series A display terminal
· 1250 High-Bright touch display terminal (Catalog Number 2711P-RDT12H)
AB repair is 4-6 weeks... which is not acceptable for this customer.
If we quote AB replacement, they will go somewhere else.
The only option I have is to find a surplus or repaired one on-line. The question I'm getting from my office is if the Series D is critical. I'm guessing it is... but that's it, I'm guessing. Anyone have experience with that question?
Panelview Plus 600
Cat: 2711P-T6M20D Ser D
Does anyone have thoughts on replacing the backlights ourselves? Allen Bradley doesn't support micro drives with parts or repair, but we still repair them ourselves. Maybe this could be the case for the Panelview?
A customer had a backlight go out on a Proface and had some Proface's on the shelf - but they all had different length bulbs from every other one.
What I ended up doing was put 2 strips of LED car marker lights, wired in series and wired to the 24VDC power for the panel.
The marker LED's were red, but it made a cool-looking screen and the customer liked it.
Didn't you take your toys apart?
Didn't you take your toys apart when you were a kid? If they can do it at AB seems you should be able to do it yourself.
People have been telling me "You Can't" all my life, That just drives me to try. I would not take the word of one AB distributor. I used to work for one selling this stuff. We did stuff in house "You Can't Do"
Well....
Panelview Plus 600
Self Repair?...Let's be aware...
I found my knack for figuring out how things worked by literally taking my toys apart and trying to mangle things together to see what I could make work, or not. I didn't always wait for them to break or go faulty either. My Father found it vexing at first but soon realized what was quickly developing. He started buying me more complicated things with electronics and radio control and I probably nearly burned the house down twice splicing and experimenting - all before I was 10. We developed and installed our own centralized vacuum system for our home and it worked a charm. We were the only ones in town that had one back then. I learned that batteries don't like being shorted out and that fuses were essential if you wanted to continuously attempt to blow something up. Eventually in my teens I was fixing everything from my neighbours appliances to my local Barbour's strimmers. I got a great sense of achievement in figuring something out or repairing something that was otherwise for the garbage. It was a learning "zig-zag" more so than a "curve", but it all played a big part in shaping and moulding my place in working life. I knew early on in school what I most likely wanted to do would be somehow technically challenging. Self repair at an early age certainly played a huge role in getting me to where I am today.
Having said that, when it comes to the professional world, I would err more on the side of caution with certain OEM equipment and attempting self repairs. HMI terminals would be one of those. For me, it's not as much about whether I can or cannot, but more about whether I should or should not. I would have to stand over any repairs I've carried out myself where the manufacturer has specifically stated not to do so. If something fails, or worse, then where does that leave me, the resonsible person?
I used to contract and had many customers. For my customers, I would prefer the guarantee or warranty provided by an authorized repair service over the uncertainty of carrying out a self repair. I now work for a multinational and while my responsibilities are now focused to just one manufacturing facility, I am still responsible for the installation, programming, maintenance and repair or replacement of our Automation install base. If any equipment goes faulty I do not entertain any of us attempting a repair if the manufacturer states it's not recommended.
Again, it's not about whether we can do it or not, or even if we agree that it's a simple repair; it's about the onus of responsibility it places upon our department and it's Engineers. It's also about efficient use of our time. If a HMI goes down, backlight or not, we replace it with a spare and then deal with the repair or replace side of things, in our own time.
Of course, just because you've had an authorized repair service carry out the work, it does not mean something cannot still go wrong. But again, what's important is that the buck does not stop with us.
I've mentioned several times before here on the Forum how we've used Lektronix regularly for our equipment repairs, including PanelView Plus 600 backlight replacement.
Here is one such previous mention...
http://www.plctalk.net/qanda/showthread.php?p=735512
Regards,
George
Hi . Please i want to help in this problem i need to change magelis backlight when alarm appare and i don't kown how i can do it ?
3,004
Anyone out there ever changed the backlight lamp in a PV1000? I could probably wing it but I would rather save the winging option as my last...
3,464
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
243
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
477
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
94
