Cicode problem
wordless
May 2009
Tehran
Hello.
I have a simple problem, I searched in help files and it didn't answer my question!
The problem is: I want a function to get a my string as an input (the input string is the name of a local variable) and return my local variable as a tag. just this!
for example:
I have several local variables like this:
BIT_1, BIT_2, BIT_3, ...
I want to set all of them to 1 by pressing a button. The code may be like this:
FOR I=1 TO 30 DO
TempVar = someFunction("BIT_" + intToStr(I));
TempVar = 1;
END
The problem is : "someFunction".
I have lots of nodes in my project that have the same parameters. So I create some super genie and pass the ID number of every instance to it. Now I need to access my local variable with this ID number.
I'm new in my job, and I'm trying to understand it.
Hope you can help me.
Thanks a lot.
Instead of using seperate local variables
Use an Array "Bits[xx]", declare as global.
Ok if is only temporay but problem if needed to be retentive.
OR use whole word
iBit = 1;
For i = 0 TO 30 DO
IF ((Word_1 BITAND iBit) = iBit) THEN;
Bit_1 = 1;
ELSE
Bit_1 = 0;
END
iBit = iBit * 2;
END
Or to set bit in word
Word_1 = Word_1 BitOr iBit;
Put in function and pass word and retrieve bit value.
Just random thoughts!
The function you are looking for is write_var (or writevar) You pass the name of a tag as a string ("BIT_" + strIndex)and it will return the value. This will only work however if the function is not used to directly display the data. On a super genie you probably should use ***_Tag or one of the other ***_ functions
(it wont let me write the first part of the function name - *** should be *=a *=s *=s)
Alternatively, you could make your local variables be tags of a disk IO device. This means you could use the TagWrite function which accepts the name of the tag as a string.
FUNCTION
SetVarToOne(STRING Variable)
INT I
STRING sTtemp
FOR I=1TO30DO
sTemp = Variable + IntToStr(I)
TagWrite(sTemp,"1")
//Display current ariable at Prompt field
Prompt(sTemp)
// Show a popup with the current variable and its value
Message(sTemp,inttostr(tagread(sTemp)),0)
END
END
In the button touch property
SetVarToOne("Bit_")
Hey People! I got an problem with the slider property, i use the scale function to show an group of images to zoom in, after this zoomin i use...
2,614
Hi All, Can anyone advise me on how to determine the AN of a genie instance I writing to. I have created a genie to display a valve and some text...
101
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
330
Hi guys, its my first time progamming cicode and I need to do popups alarms, there are several digital alarms and in their rising edge transition...
523
Hi all :) , I'm very new to CitectSCADA and Cicode programming, however have good programming experience in most major programming languages...
1,258
