Citect HMI question
IainH
Jul 2008
Sussex
44
I am developing a project using Citect HMI and am wondering if it is possible to remove or hide the white border around the last clicked object on the screen?
This should show what I mean:
Thanks.
You can change the color of the white rectangle and i thought you could change it to transparent. this would make the rectangle completly invisible. but it didnt work as expected. but this was in version 5.42 maby they changed it.
regards,
Marsupilami.
Thanks.
I know exactly what you mean but i dont think you can turn it off, the only control that i can see you have over it is in the AnmCursor section of the Citect ini file.
It is probaly possible to turn it off but how i dont know !!
The white rectangle appears around any object that has an Input Property as soon as I move the mouse over it - and remains until the mouse pointer is moved over another such object.
It's not a show stopper, but due to screen refresh and update rates, it can sometimes appear to flicker and becomes annoying to the eye.
I'm using HMI V6.0
Thanks,
Iain
OK, the answer is "Yes, there is control over it", but in reality not enough!
Using the following Citect.ini parameter you can specify the RGB value, but unfortunately you can't set it to transparent!
[AnmCursor]
Colour = 0xFFFFFF
The default value, 0xFFFFFF, is white. As I have a selection of light and dark background pages, I'll have to settle for the least annoying option.
Iain
Is there any way to access the disk I/O variables in citect V5.5, there is one tag available in the variables.dbf and it is defined as disk I/O...
1,778
Hi guys! I encountered an error on vijeo citect HMI. The system is configured as main and standby HMI. I have this error on standby HMI, "ERROR...
6,963
I’m using HMI/Vijeo Citect and I want it to take care of some calculation, not the PLC. How to do that, how do I let the Citect constantly make...
1,769
Hello All I am in the process of rebuilding several older PC 133 Ann Arbor 7000 Terminators,running Citect 5.1.Do you think that reducing the swap...
1,715
I am using Citect HMI and a WAGO PLC (750-842) communicating using MODNET (MODBUS over TCP/IP) and have the following problem: I can successfully...
8,578
