citect tag
jkbarik
Oct 2012
mumbai
Hello friends
I am using Vijeo Citect Demo. I created a slider and assigned a tag say pump_speed. A numeric display also created and assigned the same tag to see the value of the tag as I move the slider.The value of tag should change when I move the slider.But it reads zero only.The tag value should change and be displayed! Why NOT?
thanks all
Hey, I'm trying to do the following, I have some experience with Citect but can't seem to figure this out. I/O Tag: BoxPos1_ProdNum (Data Type...
607
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,183
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,988
who can teach me how to edit tag adam 4017+ in citect scada? real external I/O
885
Hello, I am using CITECT V7.2 with the ABCLX driver to communicate to a compactlogix L30ER. I want to make a simple string tag that I can key...
2,591
