CLX Sercos servo fault data?
johnfarrugi
Mar 2008
London
99
I have an application with a compact logix running three servos through a serco card. I can see in the table that there is a register allocated for axis faults it is a DINT. Where do I get the table that crossferences the integer value to the specific fault?
I am not exactly sure what is faulting on you. There can be many different things.
If is it an actual program block, then the help file with logix can help you. For example a MAS block could fault; use the index to find the MAS instruction and there will be a link to the motion error codes under the error heading in the help file.
If you are refering to the DINT in the predefined tag for your drive/amplifier, then use the manuals for your particular amplifier. For example, if you are using kinetix, get the User manual from AB. I just pulled up pub # 2094-UM001A-EN-P. Chapter 7 lists fault codes.
I believe this topic was covered on this site before as well. You could do a search for it if you haven't already (to find error codes that is).
If you have a specific problem, a more detailed description would probably get someone to help you.
Hi All Is there such a card as generic sercos card for control logix. I think I remember someone telling me about it. If so has anyone used...
2,436
Hello,:) we have two machines with two different Controllogix Motion systems . Machine #1: CLX, Analog 1756-MO2AE,1 Ultra Serie Drive for the...
7,525
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
206
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
436
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
404
