Codesys and Ethernet/IP communication to index ?
Bohardem
Dec 2016
LAval
I would like help if possible with a little problem.
I'm using a TM251MESE from schneider electric with Somachine 4.1 sp2.
I'm trying to communicate with and equipment (a BNI004A from Balluff) with Ethernet/IP (nothing too fancy here).
The BNI004A have some sensor and a Smartlight (BNI0085) on it.
I have dowloaded the EDS file of the module to my library and everything seem to work fine.
The problem i'm facing, is the equipment seems to have like 3 kind of register. The input/output of course and a Configuration.
I need to access some of the fonctions that seems to be in the Configuration register but i dont know how to access them.
I know the equipment Input said InstanceID=100, Data Length (byte) 200. Output said InstanceID = 102, Data lenght(byte) 134. And Configuration Instance ID = 102 , Data lenght ( byte) 98.
From what i know, i'm supposed to put some valu in a ISDU / index / subindex structure to modified some parameter.
I tryed using a ADDM/Write Function block but keep getting errors.
If this make sens to anyone i would apreciate some feedback ! THANK !! :)
Hello. I need to connect an EtherNet/IP adapter to CODESYS RTE. I have confirmed that the adapter works with Rockwell Logix, and not only the...
2,420
Codesys Ethernet IP Scanner - Won't connect to a Wago 750-353. The Ethernet device and the Ethernet IP Scanner are both running. but then I go...
1,668
Hi everyone, I am using Codesys for the first time (V. 3.5 SP16 Patch 3) and I have used only Allen Bradley before this. I am struggling to...
17
4,666
Hello everyone, I'm currently working on a project where I have the RPi set up as an Adapter with Codesys and the Allen-Bradley PLC as Scanner...
3,320
Does anyone in the community have some experience to help a novice understand how to use the Configuration Assembly data for an Adapter device...
7,884
