CoDeSys EtherNet/IP Scanner Configuration Assembly data
I added "ip=192.168.21.15" to the end of the line in /boot/cmdline.txt
When I reboot, the Raspberry Pi happily boots up and starts CoDeSys correctly, and all the lights go green and blinky.
I'm not sure why. cmdline.txt is one of the very first things that Linux looks at when it starts up, to configure the serial debug console. Just adding that one line doesn't set up the netmask or the gateway or the DNS servers. ...
I just found this somewhere after googling /boot/cmdline.txt
Code:
ip=192.168.1.200::192.168.1.1:255.255.255.0:rpi:eth0:off
I suspect that is
Code:
ip=RpiIP:GatewayIP:Netmask:Hostname?:Interface:Huh?
In your case, it probably does not care about the gateway, it defaults to /24 for the netmask, and there is only one ethernet port.
Some more googling would remove the question marks.
Boy did I get that wrong; apparently the code is where they are documented. E.g. check this out:
https://elinux.org/RPI_BCM2708_Parameters#module:_sdhci-bcm2708
Almost every footnote reference is a Github commit or pull request!
hahahahahahahaha
Okay, this gets you close, then here i.e.
Code:
ip=<client-ip>:<server-ip>:<gw-ip>:<netmask>:<hostname>:<device>:<autoconf>
 :<dns0-ip>:<dns1-ip>
We live in amazing times, eh?
Codesys Ethernet IP Scanner - Won't connect to a Wago 750-353. The Ethernet device and the Ethernet IP Scanner are both running. but then I go...
1,669
Hello. I need to connect an EtherNet/IP adapter to CODESYS RTE. I have confirmed that the adapter works with Rockwell Logix, and not only the...
2,423
Hi everyone, I am using Codesys for the first time (V. 3.5 SP16 Patch 3) and I have used only Allen Bradley before this. I am struggling to...
17
4,671
Hello everyone, I'm currently working on a project where I have the RPi set up as an Adapter with Codesys and the Allen-Bradley PLC as Scanner...
3,323
Hi, I would like help if possible with a little problem. I'm using a TM251MESE from schneider electric with Somachine 4.1 sp2. I'm trying to...
2,041
