Combinational logic vs Sequential logic (Petrinets) in PLC
🍻 you have even 2 hierarchical automata here ;)
Code:
FUNCTION FC 89 : DINT
TITLE =Factorial
VERSION : 0.1
VAR_INPUT
  x : DINT ;
END_VAR
VAR_TEMP
  y : DINT ;
  z : DINT ;
END_VAR
BEGIN
NETWORK
TITLE =
    [COLOR="Magenta"]  L     #x; [/COLOR]
      T     #y; [COLOR="Silver"]//y = x[/COLOR]
      T     #z; [COLOR="silver"]//z = x[/COLOR]
      L     1;
      >D    ;
      [B]JCN   B;[/B]
A:    L     #y;
      +     L#-1;
      T     #y; [COLOR="silver"]//[COLOR="Yellow"]"[/COLOR]y[COLOR="yellow"]"[/COLOR] = y - 1[/COLOR]
      L     #z;
      *D    ;
      T     #z; [COLOR="Silver"]//[COLOR="yellow"]"[/COLOR]z[COLOR="yellow"]"[/COLOR] = z * y[/COLOR]
      L     #y;
      L     L#1;
      >D    ;
      [B]JC    A; [/B]
      L     #z;
B:   [COLOR="Magenta"] T     #RET_VAL; [/COLOR]
END_FUNCTION
one with input x outputs y,z,RET_VAL ... one with inputs y , z outputs "y","z" :D
Was I clear enough ? Was I too ... simplistic ?
Now: ... is a digital PID an automaton or is it ... n o t ;) ?
Whose :D algorithm is easier modified to calculate the ... k-permutations of n function?
an advantage must pay the job
S7 has the Moore machines as FC-s and the Mealy machines as FB-s implemented !
Hierarchical (V)FSM-s have behind , the same idea and target as the structured programing ... " human understanding of the code " ... the computers don't realy need that structuring , to do a good job ! :D
( but don't forget ... it's only modeling ...and modeling is not solving but trying to ...)
No kidding: "goto" programing is structured programing fully equivalent .
(mmm ... not quite : "goto" programs are shorter/FASTER ;) ).
I am by far not an expert (I'm just an autodidact) ... but I'll try to write a (digital-)PID as a VFSM ... later
Until now I was thinking you were 1) A Troll 2) Mr. KnowItAll.
You would have had better responses with a bit more rounded style of writing. o_O
After you have made the digitall PID you could make basic MPC contoller also. :D
Which of the two types of PLC programs do you use more often at work?
16
5,472
Hi everybody, I am very new to this forum. I would to develop a combinational lock system, a program using PLC to open a lock with 2 or 3 digit...
2,487
Hello, I am going over some old code from days gone by. I would like the expert to confirm my findings to see if I got it correct. 1. B64:22/3...
452
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
172
208
