Communication Problem With Siemans S7 414-2 PLC
MarkNightingale
Sep 2010
In The VAT Shed
744
Hi All,
I am having some communication problems with a Siemans 414-2 PLC.
Basically I am trying to download some changes I have made to the PLC code through the MPI port. There is a Profibus connection in the same X1 MPI port and I am 'piggy backing' my MPI PC adapter on to the back of this. When I look for accessible nodes, none show up.
I know all my settings are correct because I have been online with the processor before.
I have also tried to connect to the X2 DP port using my PC adapter on profibus but this also did not work.
I have tried a memory reset to reset all the Baud rates back to standard but this didn't work either.
Any help would be greatly appreciated.
Mark
On 400's I believe both ports can be Profibus, if there is a Profibus connection then it is set up as Profibus and not MPI.
Check the Hardware profile of the project file to see what it is set to, MPI or Profibus and what speed.
If the second port is not used you cannot just connecct to it, a Profibus network needs a Master and termination resistors.
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
165
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
188
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,574
I am having PLC S7 200 smart model- ST 30 . In which I am getting problem in modbus communication of PLC and VFD via built in RS 485 port of PLC...
767
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,287
