Compact Logix as slave off PLC5
Mark Buskell
Sep 2003
Florida
892
I have used a SLC rack as an remote rack off a PLC5/30 before by using a 1747-ASB Module.
Can the CompactLogix be done the same way, if so what module?
The CompactLogix rack would contain some I/O Modules and a couple of analog ins and outs.
Right now there is a 13 slot rack and we would be adding the CompactLogix as rack 2.
I have a customer who has heard about the CompactLogix and is wishing to try it but I am not sure if using a SLC rack still might be the best way to go.
Thanks,
Mark
PLC5
Thanks for the info.
If I go with the CompactLogix remote rack then I have two comm modules to buy versus only one with the SLC rack.
If the application is 24 vdc discrete and analog I/O only, a lower cost alternative may be CompactBlock I/O. It is available as RIO, so you could hang it off your PLC-5.
HI there, I need that an RTU (DF1 Master) polls some data from a Compat Logix PLC (DF1 Slave) serially. I don't seem to find an application note...
2,223
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
112
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
121
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
207
265
