CompactLogix Controller Tags
LMBrian
Sep 2012
Florida
54
I currently have RSLogix 5000, (V13, V15, V16, V18 and V20) and have no issues opening any of our programs. However, I cannot seem to have access to controller tags for CompactLogix applications. I can see all controller tags in my Controllogix programs! Appreciate any ideas.........Thank you
Have you checked to see the "Scope" of the tags? (Controller vs. Program). Or am I missing the question entirely?
Got a sample program? I can handle up to V16.04.00 (CPR 9) here.
What happens while programming that makes you believe that you (by which I assume you mean one of the routines) don't have access to them? Post a screen shot of the situation if you can.
I often forget that I have a tag name filter entered when I am reading the tag database and wonder why it's suddenly truncated. Check the search filter and the Tag Type entry field.
You have a filter defined in the upper right of the tag window. Clear that filter and all tags should show.
(Just pointing out what Ken mentioned in post #4.)
Good Morning , I'm using a CompactLogix L33ER CPU . A number of my tags are going to be REAL. I looked in the processor manual , and could...
1,434
If you are creating a program to control a machine and it is a single program would it be best to create all your tags as Controller tags? If i...
2,726
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
310
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,102
Hi Everyone, I am a bit new in working with AllenBradley systems. I have a situation where an Compactlogix 5330 L30 controller is installed with...
1,886
