Compactlogix Ethernet problems
MDavidson
Mar 2007
Vancouver
23
I have a new install with a Compactlogix L43, a local rack of 6 1769 digital I/O, 2 1768 ENBT/A cards - one of which is hooked to 5 1794-AENT Flexlogix remote I/O through an N/TRON 516TX unmanaged switch. On startup I could not see the ENBT modules in RSlinx. After reading through some of the threads in this site I went to AB and grabbed the latest EDS files for the ENBT modules and the 1768 backplane. I now have access to the ENBT's, however I seem to be missing something in the setup procedure. I have assigned an I/P address, which then shows up on the modules LED display, but it still flashes the OK LED indicating I have not completed the setup procedure. What I am missing?
I have attached a few screen shots for you to look at.
Regards Mike
In addition to missing subnetmask, I see you forced ENBT to 100/full.
Did you force the switch port as well?
If not, then set ENBT back to Autonegotiation or it will give you major duplex mismatch issues.
Hi Friends
The port setting you can done only with managed switch
I have also gone through the same problem except it was control logix and compact logix
Ultimately problem had been solved by creating consumer and producer tag on both the side
Heres what I have: (1)ezTouch model EZ-T10C-FU Touch screen with Universal Ethernet port. (2)1769-L35E/A LOGIX5335E PLC I am having issues...
3,530
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
383
156
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
945
Has anyone worked with a Cosmo Air Leak Tester(LS r-902) with Ethernet/Ip, to connect to A Compact Logix, I´m doing a proyect with this equipment...
2,064
