CompactLogix Flashing red ok.
drumman32
Dec 2018
Mansfield
When I came in today one of our machines would not communicate between the HMI and the CompactLogix L27ERM QBFC1B. I cycled power to the machine a couple times with no luck. When the controller powers on the high speed counter fuse light will turn red for a while and then it will go out and the ok light will flash green. But the other ok light will flash red. I was able to see the controller in rs linx but i could not connect to it in studio 5000. it tells me the connection has timed out. I'm new to this so please be kind. lol
Check your path in 5000, if you can see it in RSLinx you can communicate to it in 5000 but odds are your using a different driver in 5000
Edit: Click on communication then select who active and see if you can find the processor then
I have a CompactLogix 1769-L18ER-BB1B that was power cycled a few times and had a mechanic pull the memory card with power on and re-insert it. At...
26
8,658
Absolute newby here. Also new to PLC. But I am a seasoned Electronics and Computer Tech. Helping to get my buddy's machine back up and running...
2,151
Good morning everyone, First post so please be gentle. Powered on a new 1769-l24er-qb1b to load a program and run some tests. PLC had a flashing...
41
16,504
Hello again. I need to flash a CompactLogix L32E from firmware ver15 to 16. It has several Panelview Plus's Series D Rev A, connected via...
2,793
Hey guys, I'm super new to troubleshooting PLCs and was hoping I could get some guidance I've got a machine I'm commissioning and it's kind of a...
27
10,557
