CompactLogix L32E communicating with Micrologix1500LRP Via DF1
heanginn
Nov 2009
johor
I need some help over this matter,
I have a compactlogix L32E and i want it to communicate with an existing micrologix 1500 LRP
what setting and programing i need to do to send data from compactlogix to micrologix and via versa? using DF1
If you have an Ethernet L32E (E is Ethernet), get a NET-ENI for the 1500 and make it Ethernet enabled. Give them IP addresses on the same subnet (192.168.1.10 and 192.168.1.11 subnet mask 255.255.255.0) Install an Ethernet cross over cable between the two. Go to the AB website and follow the examples they have (my example do not do the AB examples justice). I have done this many times and it is easy to make these two talk.
You can do this serially but depending on the distance between the processors (50' max for DF1) Ethernet is easier, faster and can be integrated into a factory network allowing historian data collection.
thanks glesniak, but my my situation requires me to use connection via DF1 that means serial to serial port connection.
Can u show me how's the configuration is set and program using MSG? coz i really don't have any clue how both controllers compactlogix and micrologix is communicated via serial port.
Hello . Info: Panelview plus 400 2711P-K4M20D Compactlogix 1769-l32E i make a program in RSlogix 5000 and Factorytalk view for...
1,823
Hello again. I need to flash a CompactLogix L32E from firmware ver15 to 16. It has several Panelview Plus's Series D Rev A, connected via...
2,806
Hello. I am trying to establish communication between CompactLogix 1769-L32E and CompactLogix 1768-L43 using serial port but with DeviceNet (and...
2,786
Respected sir/madam I have CompactLogix L32E And I want to data log into logic . is any module or card require to it. request you guid me and if...
1,407
A new member of our Forum community, maheshbhaiya, posted this as PMs and a resurrected thread, so I'm going to give it a push in the right...
2,102
