Compactlogix L32E Devicenet
mike.m
Aug 2011
Liverpool
Hi all,
Quick question, have a product that works as a devicenet slave.
I intend on using a compactlogix L32E to test the comms.
How would I go about configuring the L32E as a devicenet master? Is this even possible?
I have never used devicenet before and dont want to buy any components to assist with this as it is for a quick test.
Mike
You will need to add a 1769-SDN DeviceNet Scanner Module to your system and deploy DeviceNet media between the scanner and the slave device.
The 1769-SDN will act as the master device.
Right ok, I had a feeling I was going to need additional hardware.
Dont suppose you know of any master simulation software?
DeviceNet is pretty easy to "simulate" within RSL5K since is is a "low level" type of data transfer...Bit to Bit and nothing else...
Maybe someone else here has something better though.
What is the goal of the "quick test" ?
I've worked with some DeviceNet producs where the vendor eventually admitted they had never tested it with anything but a PC-based messaging tool before releasing it to PLC users, who of course proceeded to actually connect it to a PLC, where it was promptly overwhelmed with fast polled I/O packets.
In general, A-B devices are built to be PLC-based I/O Scanners or to be PC-based software interfaces.
For the CompactLogix, you'll need the 1769-SDN Scanner module, and RSNetworx for DeviceNet software. Since you have just one device, get a "demo copy" from your RA office and it will configure Nodes 0-5 without a license.
If you really want to do a "quick test" and not use the logic controller, you'll need an interface from one of the other DeviceNet vendors.
Hilscher, IXXAT, Woodhead... there's a lot of stuff on the market.
I can't recommend a specific device, as everything I do with DeviceNet generally has an A-B scanner.
The Hilscher "NT 50 DN EN" single-slave Ethernet / DeviceNet gateway device looks interesting, but I don't know exactly what their configuration tools do.
Since you've never used DeviceNet before, you might spend a lot more time , money, and energy attempting to circumvent the need for a PLC interface than you would spend just getting one. Most A-B offices will help you out doing a "simple test".
Hello . Info: Panelview plus 400 2711P-K4M20D Compactlogix 1769-l32E i make a program in RSlogix 5000 and Factorytalk view for...
1,826
Hello again. I need to flash a CompactLogix L32E from firmware ver15 to 16. It has several Panelview Plus's Series D Rev A, connected via...
2,814
Hello. I am trying to establish communication between CompactLogix 1769-L32E and CompactLogix 1768-L43 using serial port but with DeviceNet (and...
2,792
Respected sir/madam I have CompactLogix L32E And I want to data log into logic . is any module or card require to it. request you guid me and if...
1,415
A new member of our Forum community, maheshbhaiya, posted this as PMs and a resurrected thread, so I'm going to give it a push in the right...
2,106
