Configuration of an OPC server in ArchestrA IDE
NathBarreiros
Jan 2021
Ecuador
Hey there!
I have a query regarding the configuration of the OPC data server in the ArchestrA Galaxy, I understand that when the data server does not correspond to Wonderware, the template $OPCClient should be used, however; I don't know how to configure that server in the galaxy.
http://www.plctalk.net/qanda/attachment.php?attachmentid=57378&stc=1&d=1613430176
I would like to know if the General field is correctly configured, the server I use is RSLinx, and how I should configure the Scan Group field.
http://www.plctalk.net/qanda/attachment.php?attachmentid=57380&stc=1&d=1613430176
http://www.plctalk.net/qanda/attachment.php?attachmentid=57379&stc=1&d=1613430176
If there is any example or guide showing the configuration of an OPC server in the ArchestrA IDE it would be suitable.
Thanks in advance!!!
@Nath:
I have never used Archestra, my experience is with Rockwell Software only.
Normally the first thing you have to do is to install your OPC Server, normally this server is install on the same machine where HMI (Scada) is installed. Though in some cases I have installed OPC server on a different machine.
You have to configure your OPC server to get data from your plcs.
Then you have to connect your OPC sever to your scada and from that point on you can start to get data from plc and show data on your scada.
Hi All How can i associate items in the SLC 5/05 with OPC topic created in RsLinx Gateway. I have created a topic in Rslinx and point it to...
4,838
Hi All I would like to confirm that do i have to go through DCOM configuration settings if my OPC server and client is installed on the...
6,609
Hello, I have not configured a new OPC Link before & was needing some help please.We have TDS running that is polling Totalflow meters. I was...
1,340
Hello, We recently acquired a Siemens line and we have a station running the S7 opcdaserver. I want to test out the OPC->ODBC service from...
2,295
I've got an AB ML1400, and use the CPR9 SR2 release of RSLinx Classic to configure the DDE/OPC topic for the PLC. Although I have 16 inputs...
2,258
