Connect HMI KTP 1500 Comfort ( Using TIA) to S7-300 (Using Step 7 Manager).
phongnhatdo
Mar 2012
Singapore
38
Dear Experts.
I have one project using HMI Ktp 1500 comfort and S7-300 CPU 315-2DP.
The HMI KTP is using Software TIA porttal for programming, and S7-300 using Step7 manager.
I'm using Step 7 manager for PLC because this is require my customer. And S7-300 connect to HMI by Profibus network.
In normaly case, with HMI older version If I use Wincc flexible intergrated to Step 7 manager then it is simple. But with this situation I need some opinion from you.
my question:
- How to config network Profibus between HMI KTP 1500 comfort and S7-300 for this situation?
- how to link tag from Step 7 manager to Tia portal?šŸ™ƒ
Your best bet would be to use a "device proxy" setup.
In TIA, you create a "proxy" of the PLC.
This allows you to use the current PLC in Step 7 as well as use the PLC tags in TIA for your HMI.
Visit the Siemens site and search for "Devide Proxy" I believe they have FAQ's and a few documents describing on how to go about it.
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
345
Hello, I have an old project i did 2 years before, now i need to make a few changes but somehow i cant seem to connect to my hmi. I could access...
958
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
575
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,510
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,065
