Connect Mitsubishi FX to the Ethernet
Seppo, check your PM
DIN Rail version is ready and running.
I was told it will be for sale in a day or two on the site.
It requied 24VDC power supply and takes less than 50ma, so it can be connected to 24VDC service supply of FX PLC.
I am not sure if they will continue ant work with original adapter.
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
889
Got a used with warranty Q064UDEH It is not going to have the correct parameters to allow me to Connect the Ethernet and download the program...
428
This question is about a Q68TD-G-H01. When I disconnect the thermocouple connected to channel 8 of the module, I am expecting D111.F to go TRUE...
3,499
Hi, I would like to connect my laptop to a Mitsubishi FXCPU via the GOT serial port. I can connect using the FX-USB-AW converter if plugging into...
22
5,831
Hi all, Trying to find the best way to connect to a PLC over the internet, I'm in England....PLC is in Ireland and need remote access. How does...
2,574
