gbradley Lifetime Supporting Member Join Date Apr 2002 Location Corona, Ca. Posts 1,637 Oct 5, 2021 #1 In Connected Components Workbench how do I change the Default settings so that it shows the Name & Alias rather than Name & Wiring?
Smeltz Member S Join Date May 2021 Location Ohio Posts 20 Oct 6, 2021 #2 Right click on any instruction Name, select Properties. Click the drop down for Variable Information. Change it from Name & Wiring to Name & Alias
gbradley Lifetime Supporting Member OP Join Date Apr 2002 Location Corona, Ca. Posts 1,637 Oct 6, 2021 #3 Yes, That is what I have been doing. Going into Properties and selecting the Drop down. I was wondering if there is a way to make Name & Alias the default setting, so when I add an element it is already listed that way. Thanks
Smeltz Member S Join Date May 2021 Location Ohio Posts 20 Oct 6, 2021 #4 Tools / Options / IEC Languages / Variable Settings. Change the Variable Information setting to NameAndAlias
gbradley Lifetime Supporting Member OP Join Date Apr 2002 Location Corona, Ca. Posts 1,637 Oct 6, 2021 #5 I ended up changing the Properties of LD Container, and that did it.
