Connecting Panel View C300 via USB
DaveZR2
Feb 2010
Boston
58
I'm having a helluva time connecting my laptop to my PanelView C300. Similar to this thread: http://www.plctalk.net/qanda/showthread.php?t=40715&highlight=panelview+usb
I have a USB cable going from my laptop to the PVc USB device port. When I connected Windows automatically installed the driver (though I did not install a driver from a CD). After doing this I attempt to connect to the PanelView through my internet browser using this address: 169.254.254.2 but nothing happens.
Any tips?
Figured it out, nevermind.
If anyone else has this problem, go to start menu, settings, network connections....Find the local area connection labeled "Microsoft Loopback Adapter". Right click on it and select "Disable". Now the connection to the PanelView should work.
Hi guys!!!!: Do you have tips or any information to connect a Panel View 550 to PLC 5 via DH+?
4,874
I'm currently doing a project where we have to connect a AllenBradley PLC 5 ReadiPanel to a AllenBradley PLC 5000 over DH (RIO). in order to...
1,159
Hello to every one I have a delta plc with model dvp12sa2 As you know this type of plc has 3 coms , com2 and com3 are rs485 I want to connect...
3,985
Hi Guys I have a couple of issues with a simatic panel The first issue is that I cant connect to it. I have bought a new panel it is a simatic...
1,997
Hi I am using a S7- 400 PLC which is connected to a PLC through profibus to a ET 200M module. This ET 200M is connected to the machine . This...
34
9,999
