Connecting SLC 5/03 to Magelis through DH-485
electro89
Mar 2012
Canada
106
I'm trying to connect my SLC 5/03 to the Magelis XBTGT4330 through the RJ45 port. They both use DH485, but the pinouts are different.
For the SLC, the pinouts are:
1 RED CH. B TX/RC 1 TOP
2 BLACK CH. A TX/RC 2
3 BROWN +24 VDC 3 **
4 WHITE SIGNAL GND 4
5 BLUE TX-EN 5
6 DRAIN EARTH GND 6 **
7 GREEN SIGNAL GND 7
8 ORANGE +24 VDC 8 BOTTOM
and the XBTGT4330:
1 --
2 --
3 --
4 - D1 (+) - Send Data (Positive Signal)
5 - D0 (-) - Send Data (Negative Signal)
6 --
7 --
8 - GND - Common Ground
Tried connecting D1 to Ch B and D0 to Ch A and vice versa, but not luck! any ideas why this isn't working?
Are you sure that the Magelis has DH485 protocol? I think it just has an RS485 port but uses some other schneider protocol, not DH485. DH485 is AB's properietary protocol, which just happens to run on an RS485 type interface.
yeah, did that too.
Schneider says you would need XBT ZG939 and XBT Z9732, with RJ 45 on both ends, so I don't see why I can't just make a cable straight through
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
5,022
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,478
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,285
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,354
Hello everyone, I have a question about connecting to an S500 PLC. I have been tasked with going to site and taking a backup of a program from an...
3,902
