Connecting to Logix 5561
Cele
Sep 2006
PA
Hey guy
I really need help trying to connect to logix 5561 from Rslinx Lite i try to configure but is always failed
Please help (school proyect)
Cele
1. Connect a 1756-CP3 or 1747-CP3 cable between your PC's serial port and the 1756-L61 controller.
2. In RSLinx Lite, configure a new "RS232 Serial Devices" driver. Be certain there are no other serial drivers (especially the 1747-PIC/AIC+ driver) in use. Set the driver to use the COM port to which the serial cable is connected.
3. Click the "Autoconfigure" button in the driver configuration window.
This always, always, always, always works unless you have a damaged controller, an intentionally differently configured controller, or a PC communication port problem. It's REALLY easy.
If you can't make this work, call your local Rockwell Automation distributor and get their technical specialist to help you.
I am wondering what would be the best way to connect our 2 Process control networks to a new control logix controller (L5561 ) Can you install two...
3,813
100
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
355
134
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,285
