Connecting to Panelview 800 with CCW
Levi G
Sep 2015
Alberta
148
Hi I am trying to connect to a panelview 800 (2711R-T7T) using CCW version 9,with crossover cable going from my pc to the panelview . When I try to download to the Panelview, RS Linx pops up and it shows the Panelview 800 (I can also ping it )but when I click on the Panelview in RSLinx and click ok the output in CCW shows "device connection failed".o_O
What might I be missing here?:confused:
I have attached a screenshot from RSLinx.
Can you download to the PV via USB cable? If the answer is yes, maybe you'll need to do a factory reset on the PV to solve the problem.
I have been able to load program with a usb stick. Have not tried the cable, how do I configure the driver for usb cable? I think the web browser function is now disabled on the ones with firmware higher than 3.011. so I would have to connect with CCW to make changes
Resolved?
I am having the same issue. I cannot connect via Ethernet, so I set up the USB and get the same result. I can see the PV800 in RSLINX, and I can ping it. But when I try to connect, I get the "device connection failed" popup. Any ideas? I have also been able to copy the .cha file from the PV to my USB FlashDrive...but cannot do anything with the .cha file. I do not have a CCWSLN file for this PV.
Hello Everyone, I am a college student at the University of Wisconsin-Platteville. My professor is having me integrate a Panelview 800 HMI into...
6,903
87
Hello all! Can someone shed some light on this? I am trying to connect a PVP 6 to a PLC-5/30 through the serial ports because the old touch...
538
When I make a run time and transfer it to the PanelView Plus 6 1250 (Keypad style) I get errors saying it can see ControlLogix Slot 0 (Address of...
994
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
4,994
