Connection Allen Bradley AIC module
WallyPrestone
Aug 2005
Torrance, CA
121
Hello,
I would like to connect the internet cable with DH-485 port on the Allen Bradley AIC Module ( 1761-NET-AIC)
do you know the cable pin-out configuration .
"Internet cable" ???
I think you might mean the RJ-45 type connector, which is often used on Ethernet cables but in this case is purely DH-485 and has nothing to do with Ethernet or TCP/IP or the Internet.
It will plug into a PanelView or SLC 5/01,02, or 03 controller, but NOT into an Ethernet switch or an SLC-5/05 controller.
The cable you're probably trying to emulate is the 1761-CBL-AS09. The pinout is on the Rockwell support site as Knowbase document G16104.
Do not attempt to connect computer network card to a DH-485 port.
24VDC on DH-485 connector will permanently damage your network port!
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,276
Hello all, Who have links for documentation,- how to connect Allen Bradley 3 phases VFD PF753 in test purposes using only 230V. Approximate...
1,564
Hello everyone, this might be a stupid question but I will still ask lol I just start working at a new place and all the PLC programmer get...
1,335
Hi There, I have an application in mind using an existing Allen Bradley Micro 830. this PLC does not have on board Ethernet communications and i...
2,516
Hi all, I have an ihm and I need to connect this with compact logix PLC. In factory talk this communication works well (factory talk and fisical...
2,343
