Connection problem with CP1612 2A
all4here
Mar 2013
germany
16
hello everyone,
i have one problem...i am using siemens CP1612 2A with
6GK11612AA01 number.
i want to use the profinet system and first of all i did not find
the 6GK1161-2AA01 in the NCM library.
then i try it using 6GK1161-2AA00 but i got the error
"connection could not be established.the connection partner
is not responding"
after that i search i little bit on the internet and then i find i
solution but not successful.
i mean i use the sime IE General.
if i use the IE general then when i try to import the XBD file
then i also get the error that the selected component did not
match the existing component.
please solve my problem ....give me any idea..
i want to use the ET200S.
i have IM151-3pn and some ET200s DI and DO Module.
thank you
Have you assigned IP and Profinet Name to the IM151-3 ?
yes i did..
the second thing is i need to use the general IE or the 6GK1161-2AA00.
because in the simatic library cp1612 2A means 6GK1161-2AA01 is not available.
i have assigned the ip to the cp and IM151-3 and also name.
hello. i have one problem...this project work fine for one month and when i start the computer it works fine but now he show an error in...
968
Hello, I have an MVI56-MNET module, which is installed together with EN2TR, with a subnet of ~10, all instructions have been added to the project...
436
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
935
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,494
Hello there. I have bougth a SMC EX260 SEN-1 ethernet/ip slave and i want to control it from windows PC (with Modbus TCP may be?). Is it possible...
1,002
