connection to a master drive and a PG
robert mooli
Aug 2004
kampala
36
Hi guys am stuck i want to establish a connection btween Master siemens drive VSd and a Field PG , i have tried to to do communication confgn ie port settings but when i try to connection tells no conection established am am ussing drive monitor, please help
hi
I will give it a try:
Masterdrives have an USS port.
For communication between RS232 and USS there is a special cable from siemens. But you can build it yourself,
check: http://www.automation.siemens.com/WW/forum/guests/PostShow.aspx?language=en&PostID=75737
Check your parameters also (for example):
P700 001 0 ; Adress
P701 001 7 ; Speed (19200)
P702 001 3 ; PKW
P703 001 2 ; PZD
P704 001 0 ; No monitoring
Use the same settings in your drivemonitor
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
138
Hello- I would like to know if there is a way to monitor the status of a master connection to the EDS module on Rx3i rack. I have a master...
1,248
Hello, does anyone know the best connection method between an S71500R/H profinet MRP ring (2 x S7 1500R controllers in redundant profinet ring)...
2,934
:utoh: Hello, today tryed houres to connecting the micromaster 420 of my kaeser compressor to my laptop with the connection kit (MM4...
1,730
Hello, The problem refers to Festo servodriver. I have a Festo CMMO-ST-C5-1-LKP servodriver, I want to connect this to NX PLC via Modbus TCP...
4,637
