contact in seimens program
rowens
Aug 2003
south carolina
111
I am not extremly familiar with some things in plc logic.
I have a program for a 313 cpu has has a contact for a timer that I have not seen before.
I understand timers.
The contact is in ladder logic.
It is drawn like a normally open or normally closed contact.
It does not have the slash line across the bars for normally closed. It has a dot in it between the bars.
can anyone explain this one for me?
Click on the instruction you are unsure of and press F1, This should take you directly to the help topic related to it. If this is still no good post a picture of the logic and im sure you will get the explanation you need.
Hope this Helps
Stevo
Hello rowens;
I've just looked through the ladder logic instructions for the S7, and have not found any reference to your instruction symbol. If you have no explanation through the online help (F1), I could suggest you look at the logic in STL; it should give you more information on the instruction used. Please feel free to show us your code: either attach a zipped version of your program, specifying where we can find this instruction, of show us a screen capture.
Hope this helps,
Daniel Chartier
I appreciate the help.
I only have a printed copy of the program.
I do not yet have the seimens step 7 software to use the online help.
I am glad that this is not something everyone has seen but me.
thanks for the help so far.
Could it be a midline coil? It looks like a coil with a pound sign in it --(#)--. They're normally used to control a bit to indicate an intermediate condition.
rowens
How often has this 'contact' appeared in the print out?
If it is only once, are you sure it's not a misprint?
I have never heard of a contact the same as the one you have described.
Paul
P.S RGB, to me, this is a pound sign £
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
193
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,310
Hello all... I'm looking for a 480v 3ø 25+ amp Solid State Relay to replace a mechanical one beating itself to death keeping temp in a heating...
1,980
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,897
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,124
