PaulKraemer
- Join Date
- Jan 2005
- Posts
- 24
I have a control system with a PLC and a PC based HMI (human machine interface).
I have an application where I have two bare resistance strips through which I want to pass a current. (I will be using these to seal the edges of two pieces of mylar). The current through these strips will typically be about 8 amps at 115 VAC.
I would like to be able to control and monitor the current through these resistance strips using my PLC/HMI. Basically, if an operator enters a setpoint of 8 amps on the HMI, I need a way for this setpoint to be communicated to the current controlling device. I also would like to be able to read the actual current into my PLC/HMI so that I can check to make sure the actual current equals the setpoint current.
Does anyone know of an instrument that would allow me to do this?
Thanks in advance,
Paul
Thanks in advance,
Paul
