Control logix - change PLC name online
cjd1965
Apr 2007
UK
1,659
Hi
I have a need to change the PLC name (probably the ethernet card name) that is viewed inside rslinx during who-is. basically i have 2 with same name, different ip.
Is it possible to do online or is it an edit and download task?
Also is it possible to upload (refresh) tags without doing the whole plc. (bit like GE Series 5 , upload registers only)
I am guessing its a NO and a NO lol.
The Controller name cannot be changed online. Individual module names can be changed, but not the CPU.
Check out the Tag Upload Download utility. This is a separate tool that is included with the RSLogix software but like the other tools it is not installed unless you checked that box during the installation.
The tool does however require an OPC server like RSLinx Classic Pro/OEM/Single Node/Gateway. RSLinx Classic Lite will not work for this.
OG
Hi
If you are online, then the code is already synchronised (correlated), that's the way it works - just do a save, you will be prompted if you want to update tag data - say yes.
Hi, We have control logix system with L71 CPU as it is memory is almost full we are planning to upgrade the cpu to 4MB type cpu so If I change...
32
10,820
I have a control logix PLC that is controlling a few power flex 70's via a 20-comm e module(ethernet/IP). I need to migrate the VFD's to a...
3,608
251
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
378
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
758
