Control net card
shkoko2000
May 2011
cairo
296
Hi all,
I have main chassis and reduandancy one with The following specs:
1-Processor 1756-L62 rev 15.61.
2-Ethernet 1756-ENBT/A rev 4.3.
3-Controlnet 1756-CNBR/E rev 11.4
4-Redundancy module 1757-SRM rev 3.39
And we have 4 I/O card with control net card series D
My question if any controlnet card failure,can i replace it by controlnet card with series E and what is the steps of this replacement(need schdualing or not)
Primary and secondary chassis must have the same card with the same FW revision
I/O chassis can have any card
You do not need to schedule if you replace CNET adapter
But you must follow replacement procedure described in the knowledgbase
I have a system that is using TCP sockets. There are 5 connections between the Ethernet card and the end devices (smart conveying system)...
702
Control logix running L5K with an ethernet card failed to communicate with server running RSVIEW32k. Ploblem no communication with server. Pinged...
2,709
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
210
An outside contracting firm designed a machine for our company. There are several devices connected through Ethernet/IP. This includes a Panel...
194
I am getting random comm loss (error code 561 i think?) anyway i looked it up and its loss of comm to 2 modules on a controlnet network. The 2...
353
