Control Power Reset Lamp Color
NBJamie99
Jun 2008
Ohio
32
Hello,
I know this is off topic, but i also know you guys are all very knowledgeable. I am having trouble finding any particular documentation on what color a Control Power Reset P.B. needs to be, I have tried searches regarding standard Regs, but have come up blank. I am guessing I am not using the proper terminology, which is causing the poor search results. This was stemmed from a UK customer sales rep saying the button should be Blue, when it is normally Amber on our controls, any help would be great.
Thanks,
Jamie
In my experience it has been an industry type preference, I too have used blue or amber, with amber being the most common.
I'm not sure there are any specific regulations on this subject, however I could be wrong, as I know the Europeans are more likely to have it documented than anyone else.
Personally, on matter like this I'll pretty much do whatever the customer asks for (within reason of course).
The 'NFPA 79 - Electrical Standard for Industrial Machinery' provides these guidelines for equipment. The 2007 edition is the latest.
Non-illuminated reset push buttons should be Blue, Black, White, or Gray.
A Blue illuminated push button should be used for a "mandatory action".
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
222
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
206
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
695
Hello Members We have a controllogix redundancy setup and need to display the status of redundancy in panelview. I have found in the manual the...
1,275
Hello, I am currently working on a project that requires the equipment to vary DC power output during cycle. I need to vary from ~30VDC to...
742
