Controllogix D'Net -> 1782JDC -> Keyence
10dulkar
Apr 2004
31
I have a Keyence Laser Micrometer LS 7501 to which I need to communicate using its RS-232 port. Since the rest of the machine is Devicenet I got a RS-232/Devicenet converter from WRC: 1782-JDC.
I need help on how to use my Controllogix processor to communicate here (to send and receive data). The default tag type for Devicenet is DINT and I need to send ASCII data to it. The STOD function doesnt seem to help me to convert the ASCII string to a DINT. I think I am missing something here.
I cannot just copy the string to the devicenet output array because I need to send some SINT identifiers (length and ID). Receiving it seems more straightforward to copy just the data from the outputs to SINT, but I havent gotten to that point yet.
Any help/examples appreciated.
Thanks a lot.
I happen to have a 1782-JDC here on my desk. Nice little unit. Pretty easy to configure. I usually end up creating an array of SINT data to handle the 1782-JDC data elements.
Can you point to the ASCII protocol that the Keyence sensor uses ? Knowing the framing and protocol helps you set up length and delimiter settings in the 1782-JDC.
Hi All, Looking to get some direction on how to get data from a piece of equipment that has RS-232 communication (1-way) to a 1756-L73...
351
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
525
Something i ran into that has me stumped, hopefully someone can explain. I have powerflex 70's connected to a L7 cpu using a 1788-en2dn. The...
1,391
I'm having an issue trying to backup a ControlNet network. Within RSLogix5000, when I click on Module Properties of the 1756-CNB (Rev 5.001), the...
881
An issue occurred at an organization here in whereby the ControlNet card developed a fault. Card Details: Catalog/Series; 1756-CN2RXT B Part No...
455
