Controlnet communications
bright676
Nov 2012
va
494
What is control net communications used for? I can buy a panelview 1000, 2711-T10C15 but I am unsure of the communication set up. I am familiar with DH+ but not control net.
I am going to use it with a 5/04, panelbuilder32 and rs logix.
Is there any other special software I have to buy? Will control net even work with my 5/04?
Thanks.
Don't do it: get a PanelView with DH+.
While you could theoretically connect an SLC-5/04 via ControlNet to a PanelView, you'd have to buy an expensive (and I think obsolete) 1747-KFC15 module and connect that to the SLC's serial port.
ControlNet is great for deterministic I/O and fast messaging between ControlLogix and PLC-5C15 controllers and for ControlLogix I/O, but it's not a good fit with the SLC-500.
Hi We are running a control logix PLC system with controlnet. The controlnet has 12 nodes. Uses fiber in between the fiber repeaters . My main...
1,836
Any help on this would be GREATLY appreciated! I have an AB controlnet network with ten racks. I am occasionally getting failures, currently...
20,189
Guys, I have an application that requires testing. I have a CompactLogix L35CR connected to a VersaView CE 1250H over DF1. I have no Ethernet...
128
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
212
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,322
